Hello everyone, I am not very IT skilled and need help with setting a small network from Aerohive devices - sr2324p switch and two access points - AP250 and AP550. Any help with which cables to use and how to configure these devices would be hight ap
info114
The network will have internet from Virgin Hitron CGNV4 router in modem only mode.
I am registered to ExtremeCloudIQ device manager, but do not know how to connect my router with a switch.
10 REPLIES 10
samantha_lynn
Esteemed Contributor III
You'll want a standard cat6 Ethernet cable to connect the switch to your Router. You'll also want the same cable to connect your APs to the switch. This is an example of the type of cable I'm referring to: https://www.amazon.com/AmazonBasics-RJ45-Cat-6-Ethernet-Patch-Cable-5-Feet-1-5-Meters/dp/B00N2VILDM/...
These guides will help you connect and configure the switch: https://thehivecommunity.aerohive.com/s/article/SR22XX-and-SR23XX-Guides?language=en_US
This guide reviews how to add your devices to the ExtremeCloud IQ interface:https://thehivecommunity.aerohive.com/s/article/Adding-and-Removing-Devices-in-HiveManager
This guide reviews how to push your configuration out to your devices: https://thehivecommunity.aerohive.com/s/article/How-to-push-a-configuration-update-to-a-device-in-Hi...
If you can tell me what kind of network you'd like to set up, I can try to provide more guides to assist with this. For example:
To create an Open SSID (no password required):https://thehivecommunity.aerohive.com/s/article/How-To-Create-an-Open-SSID-in-HiveManager
To create a PSK SSID (everyone has the same password): https://thehivecommunity.aerohive.com/s/article/PSK-SSID-How-To-NG?language=en_US
To create a PPSK SSID (everyone has their own password):https://thehivecommunity.aerohive.com/s/article/PPSK-SSID-in-NG?language=en_US
To create a Radius SSID (everyone has their own username and password, plus extra security): https://thehivecommunity.aerohive.com/s/article/Radius-SSID-in-NG?language=en_US
