12-04-2018 05:12 PM
We are in the middle of a Hivemanager NG VA implementation.
One of our implementation teams has used by mistake the entitlement key destined to one site (let's call it Site implementation into another site (let's call it Site A). Both sites requires a different number of AP.
On site A we have used: hmva-signed-12.8.0.3-NGVA-2018-04-10-dell.ova
On site B we want to deploy : hmva-signed-12.8.2.2-NGVASEP18-2018-09-19-dell.ova
We want to explore the options we have in order to fix this issue:
1.- Load the right entitlement on site A (which is operational right now) and remove the entitlement key that corresponds to site B in order to install it on that site.
2.- Upgrade the Hivemanager VA on site A from 12.8.0.3 to 12.8.2.2 and move this VA from Site A to site B. Perform a fresh implementation of the VA on site A with the right entitlement key and re-associate the all the implemented APs (bear in mind this implementation is operational right now).
3.- Open a case with tech support in order to fix the issue.
Please give us your feedback about the right way to fix this issue,
Thanks in advance
12-04-2018 05:24 PM
Thank you for the feedback Sam, asI understand TS is the only one qualified to intervene the shell. That's correct?
12-04-2018 05:16 PM
For HiveManager Virtual appliances that have a key we need to remove, we'd need to reach the shell of the VA to remove the key from there. You'd want to open a technical support case for this as you'll need a shell password that a technician will have to generate for you.
