Just got AP650 without manual, how can I setup this AP? Help please!
4jumbo
8 REPLIES 8
4jumbo
I tried to open these ports but 12222 and 2083 not communicate, port 80, 443 are fine.
4jumbo
Ports need to be UDP or TCP?
4jumbo
I got POE power but it is behind PF sense. I don't know how to open ports.
ashley_finch
Contributor III
Hello,
First step is give it some PoE+ power and make sure you have firewall rules in place to allow it to contact a Cloud IQ instance. (Ports, 12222, 443, 80, 2083)
You'll need to register for a CloudIQ instance here:
https://www.extremenetworks.com/cloud-networking/
Once you receive a registration email you can begin the setup. If you have a licence key enter that, otherwise select the free "connect" option which has a limited feature set.
Otherwise, follow the below guide:
https://thehivecommunity.aerohive.com/s/article/Comprehensive-On-Boarding-Guide
Hope that helps.
