06-08-2018 12:20 PM
I'm experiencing a weird issue.
I have 11 AP connected to 1Gbps switch (same cabling and switch ports successfully tested with other devices, got about 980Mbps bandwidth).
All 11 AP are "Portal" and have the eth0 interface in Backhaul.
Using iperf (or wifi connection with a tx rate @230Mbps, 5Ghz, 40Mhz) I have less than 100Mbps bandwidth.
I tested iperf between AP devices and between AP device and iperf server(or client) in LAN. Both TCP and UDP.
Network interface is autosensing and it detect 1000Mbps on both switch and aerohive AP141 devices.
I did another test:
forcing the port to 100mbps full duplex (device and switch port), the bandwidth is about 10Mbps.
Monitoring the port traffic, the bandwith is the one reported by iperf, so no Iperf issues here.
This happens on all devices.
Any clue?
Solved! Go to Solution.
06-26-2018 08:14 PM
Hello @Giorgio Marziani de Paolis ,
I am sorry I am just now seeing this post.
It also appears I am working on this exact issue in a support ticket for your Hivemanager.
Happy to answer any questions, and will continue to work on case 240609 with Sam.
David Souri
HiveCommunity Moderator
06-26-2018 08:14 PM
David Souri
10-17-2022 12:17 PM
Hi, i have the same problem, what was the solution provided?
06-08-2018 12:22 PM
Before asking, the HiveOS version is 6.5r9a.194750
10-20-2022 09:21 AM
Hi, Is it possible to help me with this problem?
