Remote packet capture on wired interface
wim_goeminne
In Hivemanager Classic we had ability to do remote packet capture from the uplink interface.
In NG, I cannot find this feature anymore (only WIFI interfaces)
Did this feature disappear?
Thanks,
Wim
6 REPLIES 6
wim_goeminne
Hi Sam,
Sure you can fwd me the procedure
Thanks!
Wim
samantha_lynn
Esteemed Contributor III
This is correct, there is no longer a GUI option to do this with HiveManager. You can SSH in to the AP and enable a remote sniffer with the command "exec capt remote-s host-a <IPaddress>" where the IP address is the address of the device that will be running wireshark. Once you enable the remote sniffer on the AP CLI, you'd want to launch wireshark and see what interfaces it will pick up. I can send you a guide on this procedure if you'd like. It's a bit outdated because of the Packet capture feature we added to HiveManager to replace this procedure, but it will walk you through the CLI method if you're interested.
