Two of our AP121s running 6.4r1a will not update. I've rebooted both APs multiple times but every time I try to update it says "Device Update Failed"
barrettjerry6
The error message it gives is "The CLI 'save image https://cloud-va2.aerohive.com:443/afs-webapp/hiveos/images/AP141-6.5r12.img.S admin VHM-JLKLFZPN password *** basic no-prompt' execute failed, cause by: The Aerohive device was unable to save the image to flash memory. Reboot the Aerohive device and try again. If this problem persists, contact Aerohive Support."
7 REPLIES 7
MatzeKS
New Contributor III
Hi Sam, I'd be great if you can also provide me the latest "AP141-6.5r12.img.S" for AP121.
I'm unable to upgrade my two AP121 from 6.1.r1 to latest release via CloudIQ.
many thanks in advance
Matthias
barrettjerry6
Manually updating them worked. Thanks.
samantha_lynn
Esteemed Contributor III
Thanks for letting me know, I've emailed you directly with the firmware files you will need and a guide that reviews how to update firmware via the APs Web UI. We'll need to update the AP to at least 6.5r3 in order to manage it via the HiveManager.
