We have SR2324 Switches installed, with 8 clients and an uplink. Is there a reason why the memory ranges from 74% to 91% ?
shane_sanderson
New Contributor II
Clients are 3 APs and 5 IP-Phones
When running a "show process cpu" the CPU Utlisation is approx 44% (emWeb is the highest processor)
Memory is (HM shows 91%)
free - 20628
Allocated - 219708
How can we see what the memory is being allocated to?
This also seems to affect the SSH session as we are also seeing within the log
"SSH daemon is enabled. Key generation procedure can not be started"
Any ideas how to bring the memory down
1 REPLY 1
samantha_lynn
Esteemed Contributor III
Those switches do tend to run high on memory utilization, , but it shouldn't be a problem. I ran this past our experts but they didn't have any suggestions on how to lower the memory use, but they did say this is common for those models. I would recommend opening a case for the SSH issue, that sounds like something you'll need our engineers to look in to.
