Enabling Advance routing on NI-CER series
snoop42
Good day -
We have a NI-CER-2048CX-RT-AC with IP_ROUTE_SCALE and NI-CER-2048-ADV licenses on it.  We are trying to enable the ADV license so we can increase the max IP-Routes.   Any commands that need to be run specifically?   Thanks --
1 ACCEPTED SOLUTION
joergkost
Contributor II
The NI-CER-2048CX-RT-AC  comes factory installed with the IP_ROUTE_SCALE, so it looks fine. From my point of view, you only need to raise the system-max(es) and should be good.
10 REPLIES 10
joergkost
Contributor II
Does the license show up like this? Then you are ready to go.
show license
Index   Package Name              Lid          Slot    License Type    Status     License Period
1       IP_ROUTE_SCALE            $x  M       normal          active     unlimited
Else you need to copy it via TFTP
copy tftp license $TFTPSERVER $FILE
System-max:
system-max ip-cache 1200000
system-max ip-route 1200000
system-max ipv6-cache 120000
system-max ipv6-route 120000
