Hi all,
I'm going to be swapping out power supplies and fans in a VDX VCS cluster, and as part of the change is to run the command
# chassis fan airflow-direction. I've looked at the documentation and also on the CLI but there doesn't seem to be an option to apply direct to a switch via the RB option.
So my question is when you run this command is it applied to all switches in a VCS cluster at once or a switch at a time? What is the result of applying this command? I do understand the switch needs to be reloaded as part of the process.
