Confirm how to configure logical-chassis mode
Russ
Contributor
Hi I'd like to confirm the correct command to configure a VDX6740 firmware 7.2.0c.
I read in some older doco switch# vcs vcsid 1 rbridge-id 2 logical-chassis enable but this is not available and I can't recall the correct syntax and mode to execute this.
Thank you.
7 REPLIES 7
Truyen_Phan
In 7.0.x, the command is the same as the one you posted in your first post:
Thanks for the info Truyen.
Something's gone south with the firmware downgrade, I'm now in a bootloop on the switches. I'm getting an output of the boot process ATM to post here.
the boot up messages attached.-------------------------------------------
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.12.03 14:45:35 =~=~=~=~=~=~=~=~=~=~=~=
BootROM version: 1.0.76
Copyright (C) 2011 Brocade Communication.
CPU0: P3041, Version: 2.0, (0x82110320)
Core: E500MC, Version: 3.2, (0x80230032)
Clock Configuration:
CPU0:1499.400 MHz, CPU1:1499.400 MHz, CPU2:1499.400 MHz, CPU3:1499.400 MHz,
CCB:749.700 MHz,
DDR:499.800 MHz (999.600 MT/s data rate) (Asynchronous), LBC:46.856 MHz
FMAN1: 374.850 MHz
PME: 374.850 MHz
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Model ID: 131
Board: P3041 CASTOR, 36-bit Addressing
reset reason was 0x00000001: Power Up
I2C: ready
DRAM: Initializing....
Enabled DHC_EN
FSL_ERRATUM_DDR_A003 workaround applied
DIMM 0 [0xfe008174=0x8675a607] [0xfe008f38=0x11110e0c] [0xfe008f3c=0x0b0d0e10] [0xfe008f40=0x0d004004]
6 GiB left unmapped
DDR: 8 GiB (DDR3, 64-bit, CL=7, ECC on)
testdram value not set, dram test not run
Now running in RAM - U-Boot at: 7ff20000
FLASH: 4 MiB
L2: 128 KB enabled
Corenet Platform Cache: 1024 KB enabled
SERDES: bank 2 disabled
PCI: gd->brcd_flags = 0, PCI init
PCIE1 connected to Slot 1 as Root Complex (base addr fe200000)
Scanning PCI bus 01
PCIE0 on bus 00 - 01
MMK configuring pit regs
In: serial
Out: serial
Err: serial
SRIO1: disabled
SRIO2: disabled
NVRAM/RTC oscillator already turned on in a previous boot
Net: Fman: Uploading microcode version 101.6.0.
FM1@DTSEC4, FM1@DTSEC5
usb reset 0
(Re)start USB 0...
USB: Register 10011 NbrPorts 1
USB EHCI 1.00
scanning bus for devices... Manufacturer u-boot
Product EHCI Host Controller
SerialNumber
Manufacturer Generic
Product Flash Card Reader
SerialNumber 000000225001
2 USB Device(s) found
scanning bus for storage devices... 1 Storage Device(s) found
setting prt to 2
Hit ESC to stop autoboot: 5 4 3 2 1 0
Loading Environment 1 from NVRAM...
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
Loading Environment 0 from NVRAM...
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
Loading file "/boot/fastloading.mdt" from usb device 0:2 (usbda2)
158 bytes read
Image: [uImage]
Image: [hv.uImage]
Image: [silkworm.dtb]
Image: [silkworm_hct.dtb]
WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 02000000 ...
Image Name:
Image Type: PowerPC Linux Kernel Image (uncompressed)
Data Size: 473624 Bytes = 462.5 KiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 04000000
Booting using the fdt blob at 0x4000000
Loading Kernel Image ... OK
OK
Loading Device Tree to 00ff7000, end 00fff22b ... OK
Freescale Hypervisor 0.8-004
Hypervisor command line: config-addr=0x3000000 p1-linux="root=/dev/sda2 rootfstype=ext4 quiet" p2-linux="root=/dev/sda2 rootfstype=ext4 quiet ip=bootp"
[0] malloc_init: using 31 MiB at 0x7e0e38b0 - 0x7fffffff
Brocade PB device tree:brocade,SILKWORM_PB
Got liodn 125
[0] assign_callback: device serial0 in serial0 not found
[0] assign_callback: device /hvcpld in fpga not found
USB:
Static Qhead=0x4d60c0 Qhead list=0x4d6140 Qtd base=0x4d61c0
Static Qhead Align=[0] Qhead list Align=[0] Qtd base=[0]
hv scanning bus for usb devices... 2 USB Device(s) found
[0] watchdog enabled with period 38
HV> Hypervisor scanning bus for storage devices...
HV> ========Storage Device Details==========
HV> Mfr=Generic, Product=Flash Card Reader, SerialNumber=000000225001
HV> 1 HV Storage Device(s) found
HV> Init hypervisor timer init_timer:8
HV> [1] watchdog enabled with period 38
[2] watchdog enabled with period 38
HV> [3] watchdog enabled with period 38
HV> [2] Virtual Storage thread=7e22d210
HV> [0] get_rpn: mem-range has discontiguity at guest address 0x68000000.
HV>
part_start 2 2
dev_name vs_attach_guest /vsmgr/vd@usb0/vda01 part_start 2 no_of_parts 2
[vs_attach_guest]vdisk->start 0x74f7ff vdisk->size 0x74e801
Bootargs set for cpu = 2 guest p2-linux bootagrs = root=/dev/sda2 rootfstype=ext4 quiet ip=bootp
part2 STANDBY
HV>
part_start 0 2
HV>
dev_name vs_attach_guest /vsmgr/vd@usb0/vda00 part_start 0 no_of_parts 2
HV>
[vs_attach_guest]vdisk->start 0x0 vdisk->size 0x74f000
HV>
HV> Bootargs set for cpu = 0 guest p1-linux bootagrs = root=/dev/sda2 rootfstype=ext4 quiet
HV>
part1 ACTIVE
HV> [0] Clearing standby console log
HV> patch_pcie_msi_guest_node:set p2-linux msi0
HV> patch_pcie_msi_guest_node: set msi-address-64 f0000740
HV> b [0] loading binary image from 0x79fff000 to 0x3000000
HV> [2] loading binary image from 0x79fff000 to 0x3000000
[0] Loading uImage from 0x78000000 to 0
HV> [2] Loading uImage from 0x78000000 to 0
HV> [2] branching to guest p2-linux, 2 cpus
HV> [0] branching to guest p1-linux, 2 cpus
HV> this is quiet!
end of DRAM 4294967296 memstart_addr0 total_lowmem 4294967296
Using /devices/qman property 'fsl,qman-fqd'
it's a 'zero-pma', not zeroing from s/w
Using /devices/qman property 'fsl,qman-pfdr'
Qman ver:0a01,01,02
Treating Qman ver:01,02 as 0x0101
-> DMA enabled
[silkworm_setup_pci_shared_memory]config_done 0 scandone 0 pcilcok 0x0
SLUB: dfree enabled
PRIMING SLUB: main caches
SLUB: export __kmalloc at 0x40113658 changed to 0x40113a60
SLUB: export vmalloc at 0x400f72c4 changed to 0x400f7078
SLUB: export vfree at 0x400f63d0 changed to 0x400f6300
network namespace NR (VRF) started
PCI_PROBE_DEVTREE
PCI_PROBE_DEVTREE
Qman registered for failover, is currently active
Qman err interrupt handler present
Treating Qman portal ver:0x0102 as 0x0101
Qman portal at c1020000:c101e000 (0:0,v0101)
Qman portal initialised, cpu 0
Qman portal at c1028000:c1026000 (1:1,v0101)
Qman portal initialised, cpu 1
before calling: qman_release_fqid_range 512:256
Qman: FQID allocator includes range 512:256
Qman driver initialised
mmod_sysctl_inited: 1
***** pcie_portdrv_init: active completed
cpu1/1: failover_register() - registering notifiers...
Fman microcode 51 45 46
FMAN microcode UC size 0x1b64
default MII is 0xc10a8000 for tsec0
gtg_init:Coldboot case
gtg_init(1):Ring bf4f6800 Peer Ring becf6800
Uboot wdt counter value: 0
VSD Created with major number vsd_probe = 254
disk->start 0 cmd->start 0 nstart 0 disk name /vsmgr/vd@usb0/vda00
HV>
create_new_partition_table part_no 0 no_of_parts 2
HV> INIT: version 2.78 booting
Firmware Integrity Check is default off
Bypassing firmware validation.
mount: sysfs already mounted or /sys busy
mount: according to mtab, none is already mounted on /sys
mknod: /dev/fsl-hv: File exists
Hostname is sw0
INIT: Entering runlevel: 3
FIPS-mode test application
1. Non-Approved cryptographic operation test...
a. Excluded algorithm (MD5)...successful
Automatic Power-Up Self Tests...
1. DH...successful
2. FIPS RNG (AES_256_CTR_DRBG) selftest...successful
3. AES-128,192,256 CBC encryption/decryption...successful
4. RSA key generation and encryption/decryption...successful
a. RSA 2048 with 'SHA256' testing...successful
5. TDES-CBC encryption/decryption...successful
6. HASH and HMAC tests...
a. SHA-1 hash...successful
b. SHA-256 hash...successful
c. SHA-384 hash...successful
d. SHA-512 hash...successful
e. HMAC-SHA-1 hash...successful
f. HMAC-SHA-224 hash...successful
g. HMAC-SHA-256 hash...successful
h. HMAC-SHA-384 hash...successful
i. HMAC-SHA-512 hash...successful
7. Zero-ization...Successful
8. ECDSA ...successful
9. ECDH ...successful
10. TLS KDF 1.0...successful
10a. TLS KDF 1.2...successful
11. SSH KDF...successful
sysmodAttach open failed: No such device or address
system_parameter_init: sysModInit() failed(2)12. SNMP KDF...successful
All tests completed with 0 errors
GTG Peer GOS reset
(none)
Waiting to starting configuration management service
Starting configuration management service
[wmd_init]: chunk_size = 0xa00000
[wmd_init]: WM reset
Found 1(threshold 5) abnormal reboots within 5000 seconds window(threshold)
KernelSpace rastrace_register
DCM MODE:0x0
SWBD module launch ... Fri Dec 3 03:10:30 GMT 2021
CPLD INIT DONE
SEEPROM Read Done!
Cobra rev B found
Info: panic dump has been initialized!
Starting HASM ... Fri Dec 3 03:10:47 GMT 2021
LAUNCH HASMD 131 0x0 0Exisitng reboot reason fsize = 5 rb=
Global Fan Direction: Port Side EXHAUST
Network OS (sw0)
sw0 console login: Castor: PCIe Err handler init plat_pci_init[800]
bhpc_irq_init: Using default device map. Size 10
bhpc_irq_init: Pcie domain 0 err interrupt handler Installed
Starting Dcmd ... Fri Dec 3 03:10:50 GMT 2021
server starting
Restoring DCM database2048 indexes lost
.free list corrupted, idx 651 already assigned!
.tp_register, got none fss tp handle=10000001h
2021/12/03-03:10:55, [HSL-1012], 1, INFO, VDX6740, Interface lo is link up
2021/12/03-03:10:55, [HSL-1012], 2, INFO, VDX6740, Interface eth0 is link up
2021/12/03-03:10:55, [HSL-1012], 3, INFO, VDX6740, Interface eth1 is link up
2021/12/03-03:10:55, [HASM-1004], 4, INFO, VDX6740, Processor reloaded - Reset.
.....done
disk->start 7665663 cmd->start 0 nstart 7665663 disk name /vsmgr/vd@usb0/vda01
HV>
create_new_partition_table part_no 2 no_of_parts 2
HV> [3] restart_guest_remap: self is calling remap_restart_unc due to standby and hcall_partition_restart_ha.
HV> GTG Peer GOS reset
waiting for server to shut down............................... done
server stopped
HV>
HV> [3] Hypervisor Resetting due to: hcall_system_reset
[3]
Hypervisor Reset Flush:
HV>
CCB:749.700 MHz,
FMAN1: 374.850 MHz
PME: 374.850 MHz
Model ID: 131
reset reason was 0x00000002: CPU request
I2C: ready
Enabled DHC_EN
6 GiB left unmapped
FLASH: 4 MiB
L2: 128 KB enabled
Scanning PCI bus 01
In: serial
Out: serial
Err: serial
SRIO1: disabled
SRIO2: disabled
usb reset 0
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
158 bytes read
Image: [uImage]
Image: [hv.uImage]
Image Name:
OK
Got liodn 125
USB:
HV>
part_start 2 2
part2 STANDBY
HV>
part_start 0 2
HV>
HV>
HV>
HV>
part1 ACTIVE
HV> b patch_pcie_msi_guest_node: set msi-address-64 f0000740
HV> [0] loading binary image from 0x79fff000 to 0x3000000
HV> this is quiet!
Qman ver:0a01,01,02
-> DMA enabled
SLUB: dfree enabled
PCI_PROBE_DEVTREE
PCI_PROBE_DEVTREE
cpu0/0: failover_register() - registering notifiers...
HV>
Hostname is sw0
1. DH...successful
GTG Peer GOS reset
(none)
Found 2(threshold 5) abnormal reboots within 5000 seconds window(threshold)
DCM MODE:0x0
SWBD module launch ... Fri Dec 3 03:17:28 GMT 2021
CPLD INIT DONE
SEEPROM Read Done!
Cobra rev B found
Starting HASM ... Fri Dec 3 03:17:46 GMT 2021
Network OS (sw0)
sw0 console login: Global Fan Direction: Port Side EXHAUST
Starting Dcmd ... Fri Dec 3 03:17:51 GMT 2021
2021/12/03-03:17:53, [HSL-1012], 5, INFO, VDX6740, Interface lo is link up
2021/12/03-03:17:53, [HSL-1012], 6, INFO, VDX6740, Interface eth0 is link up
2021/12/03-03:17:53, [HSL-1012], 7, INFO, VDX6740, Interface eth1 is link up
2021/12/03-03:17:53, [HASM-1004], 8, INFO, VDX6740, Processor reloaded - Reset.
server starting
Restoring DCM database...done
Network OS (sw0)
sw0 console login: admin
Password:
2021/12/03-03:18:22, [SEC-1206], 9, SW/0 | Active, INFO, sw0, Login information: User [admin] Last Successful Login Time : Fri Dec 3 01:08:31 2021
Error: Network OS is not ready. Please login later.
2021/12/03-03:18:23, [SEC-3022], 10, SW/0 | Active, INFO, sw0, Event: logout, Status: success, Info: Successful logout by user [admin].
Network OS (sw0)
sw0 console login:
HV>
waiting for server to shut down........................ done
server stopped
Fri Dec 3 03:23:28 GMT 2021 :: Confd: Waiting for Dcmd to become ready...
Services starting COLD recovery
CHASSIS RECOV_ACTIVE
Activating Route Profile [RTPROFILE_TYPE_DEFAULT], ecmp [0]
Activating HW Profile [HWPROFILE_TYPE_DEFAULT]
Activating KAP Profile [DEFAULT]
SNMP Research EMANATE/Lite Agent Version 16.2.0.9
Copyright 1989-2006 SNMP Research, Inc.
dcm init successful
Confd: No need to wait for Ccmd...
Fri Dec 3 03:23:43 GMT 2021 :: Triggering confd load phase1 after waiting for 10 secs
HV>
HV> Passed :: register_for_publisher_notification for MSG_TNL_GW_CONF_NOTIFY passed for NSMD.
Subsribed successfully for NSMPORTDECFGMSG in rmond
radv trace initialization succeeded.
srm trace initialization succeeded.
arp trace initialization succeeded.
vrrp_tha_init: regdone handle 1
ARP trace init Successful
VRRP_tha_Init: stage 1 done
ribmgr trace initialization succeeded.
pcap_master_init - sm is NULL after ha_calloc
rps trace initialization succeeded.
Current Mode of Op:interrupt Vs Thread State:0x2 blockPos:4
Current Active cookie Gos0:21917 Gos1:2168
Current Queued max cookie Gos0:21918 Gos1:2168
Guest sem info data 0x0 waitlist 0x0
HV>
calling system reset from vs_thread_worker:
[2]
HV>
since guest is stopping don't accept any io:hcall_submit_aio
HV>
CCB:749.700 MHz,
FMAN1: 374.850 MHz
PME: 374.850 MHz
Model ID: 131
I2C: ready
Enabled DHC_EN
6 GiB left unmapped
FLASH: 4 MiB
L2: 128 KB enabled
Scanning PCI bus 01
In: serial
Out: serial
Err: serial
SRIO1: disabled
SRIO2: disabled
usb reset 0
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
158 bytes read
Image: [uImage]
Image: [hv.uImage]
Image Name:
OK
Got liodn 125
USB:
HV>
part_start 2 2
HV>
part2 STANDBY
HV>
part_start 0 2
HV>
HV>
HV>
HV>
part1 ACTIVE
HV> this is quiet!
Qman ver:0a01,01,02
-> DMA enabled
SLUB: dfree enabled
PCI_PROBE_DEVTREE
PCI_PROBE_DEVTREE
HV>
Hostname is sw0
1. DH...successful
GTG Peer GOS reset
(none)
Found 3(threshold 5) abnormal reboots within 5000 seconds window(threshold)
DCM MODE:0x0
SWBD module launch ... Fri Dec 3 03:25:10 GMT 2021
CPLD INIT DONE
SEEPROM Read Done!
Cobra rev B found
Starting HASM ... Fri Dec 3 03:25:28 GMT 2021
Network OS (sw0)
Starting Dcmd ... Fri Dec 3 03:25:34 GMT 2021
2021/12/03-03:25:35, [HSL-1012], 11, INFO, VDX6740, Interface lo is link up
2021/12/03-03:25:35, [HSL-1012], 12, INFO, VDX6740, Interface eth0 is link up
2021/12/03-03:25:35, [HSL-1012], 13, INFO, VDX6740, Interface eth1 is link up
2021/12/03-03:25:35, [HASM-1004], 14, INFO, VDX6740, Processor reloaded - Reset.
server starting
HV>
HV> [2] restart_guest_remap: self is calling remap_restart_unc due to standby and hcall_partition_restart_ha.
Network OS (sw0)
sw0 console login: ..admin
.Password: ..
.2021/12/03-03:29:47, [SEC-1206], 15, SW/0 | Active, INFO, sw0, Login information: User [admin] Last Successful Login Time : Fri Dec 3 03:18:22 2021
...Error: Network OS is not ready. Please login later.
.2021/12/03-03:29:51, [SEC-3022], 16, SW/0 | Active, INFO, sw0, Event: logout, Status: success, Info: Successful logout by user [admin].
Network OS (sw0)
sw0 console login: ...............
Original Message:
Sent: 12-02-2021 22:51
Subject: Confirm how to configure logical-chassis mode
Original Message:
Sent: 11-29-2021 22:05
Original Message:
Sent: 11-29-2021 18:48
Thanks again, for reference what was the command to configure logical-chassis mode?
Original Message:
Sent: 11-29-2021 01:12
You will need to downgrade to 7.0.x, then set the vcs mode to logical chassis, then upgrade.
Original Message:
Sent: 11-29-2021 01:03
Hi thanks for you reply. When I was checking the status after applying the VCSID and RB ID the output indicated that the switch was in VCS Mode : Fabric Cluster and not logical-chassis.
Original Message:
Sent: 11-29-2021 00:55
Hi Russ,
Starting NOS 7.1.x and higher, the only valid VCS mode is logical chassis which is enabled by default, so there's no need to configure logical-chassis enable anymore. You just need to set the VCS ID and RB ID.
Original Message:
Sent: 11-28-2021 21:36
Thank you.
