VDX-6740 with logical chassis cluster monitor via BNA issue
Vicky_Wand
Hello,
I have 18 VDX-6740 in one logical chassis cluster, and use BNA to monitor those devices.Recently I removed one node from the logical chassis, and I try to delete this node in BNA. However the message shows "Active member in the cluster cannot be deleted" .
Does anyone know who to update the fabric/node in BNA?
2 REPLIES 2
Vicky_Wand
Hi support,
I already remove the device from logical chassis cluster.
However, BNA monitor tool didn't update this change. It keep shows the device in ethernet fabric with degraded link.
I also try to "Rediscover" in BNA. But nothing change.
Do you know how to update this?
Regards,
Vicky
TechHelp24
New Contributor II
Vicky,
whitout any kind of warranty..... otherwise ignore my post.
in order to delete any registered chassis, as fair as i remember, you have first to romove it in VCS.
example form a command reference manuals:
vcs logical-chassis enable default-config
Use the no form of this command to remove a node from an existing cluster, remaining in logical chassis cluster mode.
Syntax
no vcs logical-chassis enablerbridge-id rbridge-id default-config
