01-18-2021 07:00 PM
Hi
I have a large qty of Product codes that I need ECCN codes for, do you have a portal or pdf by range that would help us self service
thanks
01-20-2021 03:02 PM
Stephan is absolutely correct, your sales contact can provide you with this information. Also if you are a partner with us, you can go to extremenetworks.com> click “Log In” in the top right corner> Select PartnerEngage from the drop down menu> Log in> Scroll down to “Find Content” and click on “Price Lists”> Look for the “WW Reference Info” spreadsheet> Find the the “Trade Matrix” tab in the WW Reference Info Spreadsheet> Here you will see the ECCN# for our products. Hope that helps!
01-19-2021 04:31 PM
Hello,
the best way to receive the mentioned data is to contact you sales or SE contact.
