‎05-11-2023 06:13 AM
Trying to access a distant SQL database from a workflow, I'm unable to import relevant python module. Is this natively possible or should I installed additionnal python module ? And if yes, how ? Older post talk about former XMC, but seems not to be effective in XIQ-SE.
Regards.
Jave
Solved! Go to Solution.
‎05-12-2023 06:39 AM
Officially I do not think there is a means to import modules in either Python or Jython as used by XMC/XIQ-SE.
XMC/XIQ-SE includes python2.7/python3 command line interpreters but primarily uses Jython - a Java-based python interpreter for its GUI-based Python script executions.
While it's likely possible to tweak the system to use pip, etc to import modules for either I do not think formally this is supported.
To add formal support would be a product enhancement / feature request.
‎05-14-2023 11:44 PM
You may consider using the build-in driver. more details in the XIQ-SE licensing calculation workflow:
from com.ziclix.python.sql import zxJDBC
try:
cnxn = zxJDBC.connect(url,emc_vars["dbUser"], emc_vars["dbPassword"], driver)
mycursor = cnxn.cursor()
mycursor.close()
cnxn.close()
except:
status = emc_results.Status;
emc_results.setStatus( status.ERROR )
emc_results.put("workflowMessage","MySQL Database access issue, check the password in Variables!")
wf_error("MySQL Database access issue, check the password in Variables!")
else:
wf_info("MySQL Database access OK.")
‎11-08-2024 09:55 AM
If you replace the MySQL driver with PSQL driver you should be able to re-use majority of the workflow. basic SQL commands are the same for MySQL and PSQL...
# Try the DB connection and if it is not successful than stop
url = 'jdbc:postgresql://localhost:4589/netsight' #URL with port and database name
driver = 'org.postgresql.Driver'
try:
mycursor.close()
cnxn.close()
except:
emc_results.put("workflowMessage","Database access issue, check the password in Variables!")
else:
print ("Database access OK.")
‎05-12-2023 06:48 AM
See https://community.extremenetworks.com/t5/extremecloud-iq-site-engine/xmc-and-python-install-addition...as this is a group provided script that essentially uses PIP within Jython to import modules. Modules must be Python 2.7 compatible.
... this is of course not GTAC supported
