Analytics - dual interface deploy
EF
Contributor III
Hi team,
Im deploying Analytics engine in rel 23.11.11 for VOSS and in the configuration itiall wizard I can see these net options:
They are differents to old versions in which dual interface was included.
My question is, Does Analytics still support dual interface topo (one for mgmt and one for data) or is it deprecated?
Regards
EF
1 ACCEPTED SOLUTION
Zdeněk_Pala
please use GUI to define the use of NICs. we updated the documentation to be more clear.https://emc.extremenetworks.com/content/oneview/docs/analytics/analytics_tab/configuration/c_pur_ana...
you can have eth0 in Management Only and eth1 in Monitor ERSPAN
good luck
Regards Zdeněk Pala
1 REPLY 1
Zdeněk_Pala
good luck
Regards Zdeněk Pala
