application analytics engine "127.0.0.1 does not support network services dashboard"
‎12-01-2016 07:45 PM
Hello,
We just implemented an analytics testbed in netsight 7.0.5.12. If I look at the network services in the analytics dashboard tab, it reports the data properly. However, if i create a report using "Network Service Response Time Data" within report designer and try to view the report, it gives me the pop-up message "127.0.0.1 does not support network services dashboard".
Is this by design? Thanks much.
8 REPLIES 8
‎03-24-2017 03:48 PM
Joshua is correct. Hope to have some additional detail soon.
‎03-24-2017 12:34 PM
FYI, The case has been handed off to engineering, so it looks like we are waiting on a GA release to fix the issue.
‎12-02-2016 10:54 AM
I typically use Firefox, occasionally chrome. I haven't been able to successfully load it yet in a report, but I'll keep trying and bring it up with GTAC. Thank you for testing.
Hi Joshua,
I have the case and investigating the issue now. Thanks
Jeff
Jeff
