The most basic advantages/disadvantages between them are:
B@controller:
-- Ease of administration. If you want to add a new VNS/WLAN that contains traffic to a new VLAN, you only have to tag one port on the controller and you're done. If you want to do the same thing with B@AP topologies ... you would have to tag every AP port and all the interswitch links between all edge and distribution switches (if you have them) up to your core as well.
-- All traffic is brought back to the controller and out only one or a few ports (if you create a LAG)
B@AP
-- More work to administer (see above)
-- Traffic is distributed across as many ports as you have APs
Whether one is "better" than the other or not depends on your design choice and requirements. If you have a controller in a central location, say Dallas ... with all your APs in remote locations ... Boston, Detriot, LA, SF etc ... then it probably doesn't makes sense to tunnel all that traffic back to the controller ... when a lot of it will have an ultimate destination of some other device in the remote location the packets were sourced from. Also, if you have a small network with not that many APs and a limited IT staff ... it may not make sense to overly complicate the design ... and with 10-15 APs and a hundred or two hundred clients connecting through them (just numbers I'm throwing out there .. NOT hard limits or recommendations) you may have an easier time sticking to B@controller topologies in terms of the work involved ... and you may see no issues with performance.
In your case ... 300+ APs ... it may make sense to move some or all topologies to B@controller ... if you are prepared to do the work to build out ALL your VLANs to all AP ports and the switches that serve them ... but ultimately you are the best one to decide that. If you do it, you may see benefits in breaking your client traffic up over 300+ AP ports vs. tunneling all your traffic back to your two controllers and egressing that traffic out a handful of ports, but you will add additional work to maintain and grow the solution as well.
Hope this helps.
