10-24-2019 02:14 PM
11-13-2019 07:10 AM
Hi.
I believe the issue is:
We added the proper “HTML/XML” encoding later to the XMC. the > is not translated during the import and not recognized during the execution
The option 1 for you:
Option 2 for you:
Good luck!
11-14-2019 09:09 AM
Many thanks
11-13-2019 07:10 AM
Hi.
Option 2 for you:
Good luck!
11-12-2019 02:47 PM
The version of XMC is: netsight_appliance_64bit.8.2.3.67-Small.
It was deployed as a VM.
I added the ERS 3600 into XMC first, so, it can communicate over snmpv3.
But when I want to run this script against it, I got this message as I described.
Thanks in advance.
11-11-2019 07:18 AM
strange. I just tested and I did not get any error. it worked for me. Can you please be more descriptive about what you did?
What is your XMC version? Was your XMC deployed as VM or as Exe or bin?
