Can I enforce an Avaya ERS3600 into NAC demokit? see screenshot that this is not possible.
Sacha_Brys
Contributor
1 ACCEPTED SOLUTION
Zdeněk_Pala
Hi.
I believe the issue is:
We added the proper “HTML/XML” encoding later to the XMC. the > is not translated during the import and not recognized during the execution
The option 1 for you:
  • replace > with >
  • replace &lt; with <
Option 2 for you:
  • download attached TXT
  • edit your script and paste the content of the TXT file
  • save
Good luck!
Regards Zdeněk Pala
8 REPLIES 8
Sacha_Brys
Contributor
Hi, sorry for the delay, I did follow the procedure.
But I always get the error:
SyntaxError: ("mismatched input ';' expecting COLON", ('<string>', 22, 24, '    if len(sys.argv) &gt; 1: # Json file as 1st argv\n'))
thanks in advance
Zdeněk_Pala
Hi.
Please check if your procedure is correct:
  • Download the XML file (the link is correct)
  • Import the script:
    • XMC version 8.0 = In the Extreme Management Center -> Administration -> Scripting -> Import…
    • XMC version 8.1.2 and newer = Import the sctript = In the Extreme Management Center -> Tasks -> Scrips -> Import
Regards Zdeněk Pala
Sacha_Brys
Contributor
Hi thanks for the info you gave. Allthough I’m totally new in this 😉
I tried the script (Python)
https://raw.githubusercontent.com/extremenetworks/ExtremeScripting/master/Netsight/oneview_CLI_scrip...
but from the beginning I got the message:
Date and Time: 2019-10-25T02:51:08.796
EMC User: root
EMC User Domain:
IP: 192.168.10.222
SyntaxError: ("no viable alternative at character '?'", ('<string>', 1, 1, '<?xml version="1.0" encoding="UTF-8" standalone="yes"?>\n'))
What is going wrong
thanks again
Zdeněk_Pala
The ERS does not support radius configuration through SNMP.
To configure ERS with NAC we recommend to use ERS NAC Enforce scritp from Github.
Regards
Regards Zdeněk Pala
