Can't open Netsight Console!
Rahman_Duran1
New Contributor III
I can't seem to open Netsight Console on Windows10/Jre8_latest. I get nullpointerexception every time.
0ee5310a40664476bda35f1ff1e5d3e4_RackMultipart20151104-21414-7b08vj-exception_inline.png
I can open InventoryManager but not Console.
Any idea what should be the problem?
11 REPLIES 11
Rahman_Duran1
New Contributor III
Well, I can't try it on a different computer now. Will try it later. I clear all temporary java files from java settings console and retry to run console.jnlp. Still the same error.
Edit: I just tried it on Windows 7 SP1 machine with java 8. Same error.
Bharathiraja__S
Hi Rahman,
If you check with different computer is it working ?
Thanks,
Suresh.B
