Capacity planning in Extreme Management Centre 8.0.3
‎11-03-2017 09:42 AM
I have looked extensively and there does not seem to be a way to provide a report based on used/un-used ports over any period of time that used to exist in Inventory Manager.
There was youtube video posted about archives but it doesn't outline how to generate the reports.
Can someone please enlighten me
8 REPLIES 8
‎07-18-2019 11:43 AM
That might work fine, if we didn't need to provide the port to another group, plus we need it for over 100 devices. That was why the Inventory Manager Report was so useful.
‎01-23-2018 03:27 PM
It should be a pre-populated report under the Reports Tab.
Doug Hyde
Director, Technical Support / Extreme Networks
Thank you but I dont see a reports tab in the latest version
‎11-04-2017 12:12 PM
I would also like to know this!
It appears that there used to be a Capacity Planning Report that you could run from Inventory Manager (the legacy Java console). But since that no longer exists - I cannot seem to find where this report ended up being moved to in the web interface?
Here is a GTAC that describes the old functionality.
