Capacity planning in Extreme Management Centre 8.0.3
stephanos_kaish
New Contributor II
I have looked extensively and there does not seem to be a way to provide a report based on used/un-used ports over any period of time that used to exist in Inventory Manager.
There was youtube video posted about archives but it doesn't outline how to generate the reports.
Can someone please enlighten me
8 REPLIES 8
That might work fine, if we didn't need to provide the port to another group, plus we need it for over 100 devices. That was why the Inventory Manager Report was so useful.
Doug
It should be a pre-populated report under the Reports Tab.
Doug Hyde
Director, Technical Support / Extreme Networks
Thank you but I dont see a reports tab in the latest version
Steve_Ballantyn
Contributor
I would also like to know this!
It appears that there used to be a Capacity Planning Report that you could run from Inventory Manager (the legacy Java console). But since that no longer exists - I cannot seem to find where this report ended up being moved to in the web interface?
Here is a GTAC that describes the old functionality.
