Changing 'Parent Map' in Extreme NMS v8.0.3.46 breaks the map
Steve_Ballantyn
Contributor
I seem to have an issue with the latest Netsight. When I change a map's parent map setting, the map becomes a dead link with no details.
Once it's moved, I can no long select it from the tree. If I try to right-click and edit the properties, it shows me the properties of the loaded map instead of the broken one.
Before I open a ticket, can anyone confirm if this is a bug, or just me?
1 REPLY 1
Steve_Ballantyn
Contributor
OK - I rebooted the Netsight box, and all is well now. Must have been a glitch!
