‎01-06-2022 01:23 PM
If I right click on one of my switches > configure > enforce preview at the I see in the Match column Device, VLAN Definitions, LAGs, Ports. Some of my switches show that VLAN definitions are "Not Supported" some of my switches show LAGs as Not Supported...
Is this due to a the model of the switch, a firmware version, an option that is not enabled, licensing, etc...?
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎01-07-2022 07:43 AM
Hi Michael
capabilities (tabs) displayed in the Right-click > Configure depends on the device type and firmware. The management has the capabilities to filter some unsupported features.
Z.
Z.
Regards
Zdeněk Pala
1 REPLY 1
Hi Michael
Z.
Z.
Regards
Zdeněk Pala
