12-09-2019 03:17 PM
Does anyone know how to create a new group in the Access Control-Configuration-Policy Mappings tab in Extreme Control? The documentation I’ve seen to have found points to adding a new policy mapping in the default group, but I want to create a policy mapping in my own group if possible.
Thanks!
12-25-2019 08:37 PM
you can have more policy mappings based on location. In the example there is location Building1 with other mapping compare to rest of locations.
If you want to use policy mapping based on something else then location then you should use different NAC rule conditions.
