09-13-2022 06:36 AM
After creating some Service Definitions into our XIQ-SE instance, a site "/Service Definitions" appears by default for each item in the Network/Dashboard/Inventory/Summary", which is not useful, as you can see on this screenshot:
We need each time we want to use this dashboard to select "/World" site. Does anyone knows if it's possible to change this behaviour ?
Regards.
09-14-2022 12:39 PM - edited 09-14-2022 12:40 PM
Hi Jav.
it looks very strange. I do not see such behavior in my lab environment. Only real sites are listed.
What version are you using? If the restart does not help then I would suggest creating a support ticket to get this fixed.
09-16-2022 12:20 AM
Hi Zdeněk,
I'm running the latest version 22.6.12.13. And yes, restarts have already happend without change...
So Im' going to open a case, thanks.
Jave
