DemoKit using Esxi must need 2 physical network interface cards ?
ahmeds
hey everybody
I am trying to implement the demo kit lab using Fujitsu server and X440-g2-12p and AP 410c
but, I have a problem that when I add xcc VM is required to have 2 physical NICs and the Fujitsu workstation j580 only have 1 NIC
is there a solution?
1 ACCEPTED SOLUTION
Antonio_Opromol
Contributor
Hi, in the old DemoKit (now is EOS), the XCC has got 3 interfaces and the nic0 is not connected, the nic1 is connected to VMNET10 (192.168.10.0/24) , and the nic2 is connected to VMTAP (see screenshot attached).
I hope this help you.
1 REPLY 1
Antonio_Opromol
Contributor
