Hi together,
we have massive problems with EMC, p.e. the search field ist not displaying, in a wrong position, or if we open a end-system under "control" we see a fault view (too small) and no tabs appear.
Extreme cannot resolve this issue and there is no solution until this moment.
But I have found a workaround. If I deactivate the "live" view under:
Administration > Options > Access Control > Live End-Systems Table Updates
the live view is per default in the status "paused" and all works fine.
Maybe this will help other people with similar problems.
Regards
Michael
