Documentation on how to Migrate XMC to XIQ-SE?
Byron_Morales
New Contributor II
Are there any guides on how to upgrade or migrate Extreme Management Center to the new XIQ-SE?
1 ACCEPTED SOLUTION
Zdeněk_Pala
Thank you Mark.
I see, we have typo there.
The upgrade to 21.4.10.99 is not tested from 8.5.6. as 8.5.6 was released after the 21.4.10.99.
If the customer is on 8.5.6 and wants upgrade to XIQ-SE then there are two options:
  • wait for 21.9
  • ask GTAC for 21.4.11
Regards Zdeněk Pala
15 REPLIES 15
Zdeněk_Pala
Hi.
can you please check what is the version with the reference to 21.07. ? It seems like an internal development version, not a GA.
The official version is here: https://emc.extremenetworks.com/content/oneview/install/suite_install.html#upgrade_info
Thank you.
Regards Zdeněk Pala
Stefan_K_
Valued Contributor
Hehehe, indeed. Strange. 🙂
Mark_Severijnen
Hi Stefan,
It keeps on getting more confusing.
I have Release notes for 21.4.10 dated Mai-2021 in which you only see:
So there must have been a sneaky upgrade of the release notes.
Stefan_K_
Valued Contributor
This screenshot is from the release notes of 21.04. It seems that 21.07 isn’t a typo, because there are  other references about 21.07. For some reason this version wasn’t released or is postponed.
https://documentation.extremenetworks.com/release_notes/NetSight/XIQSE/XIQSE_21.04.10_Release_Notes....
Mark_Severijnen
Hi Stefan,
Sorry, but no typo as in the posted release notes there is also legacy xmc 8.5.6 mentioned, in the release notes of 21.04.10 one does not see anything about that.
regards,
Mark
