‎09-01-2021 05:15 PM
Are there any guides on how to upgrade or migrate Extreme Management Center to the new XIQ-SE?
Solved! Go to Solution.
‎09-03-2021 02:31 PM
Thank you Mark.
I see, we have typo there.
The upgrade to 21.4.10.99 is not tested from 8.5.6. as 8.5.6 was released after the 21.4.10.99.
If the customer is on 8.5.6 and wants upgrade to XIQ-SE then there are two options:
‎09-03-2021 02:05 PM
Hi.
can you please check what is the version with the reference to 21.07. ? It seems like an internal development version, not a GA.
The official version is here: https://emc.extremenetworks.com/content/oneview/install/suite_install.html#upgrade_info
Thank you.
‎09-03-2021 01:31 PM
Hehehe, indeed. Strange. 🙂
‎09-03-2021 01:28 PM
Hi Stefan,
It keeps on getting more confusing.
I have Release notes for 21.4.10 dated Mai-2021 in which you only see:
So there must have been a sneaky upgrade of the release notes.
‎09-03-2021 01:02 PM
This screenshot is from the release notes of 21.04. It seems that 21.07 isn’t a typo, because there are other references about 21.07. For some reason this version wasn’t released or is postponed.
‎09-03-2021 12:30 PM
Hi Stefan,
Sorry, but no typo as in the posted release notes there is also legacy xmc 8.5.6 mentioned, in the release notes of 21.04.10 one does not see anything about that.
regards,
Mark
