Hi Guys,
I'm having an odd behavior in a customer running EMC/NetSight 7.1.2.12 (mixed SecureStack and Summit switches).
After the NetSight upgrade to 7.1.2.12, during the install of new Summits (replacing the old E1s) we found that a B5 stack, without any known reason had the empty port aliases replaced by SYSNAME_ge.x.y... (i.e. B5-CPCOM-01_ge.1.1). By the way, this switch is running for years, and haven't been touched during this procedure, because it is installed on other site.
Taking a look at the Console logs, I found something odd... The NetSightServer was setting the aliases by itself:
![](https://d1uyvls174j03l.cloudfront.net/extremenetworks-us/attachment/RackMultipart20170810-109119-sm2i5k-Captura_de_Tela_2017-08-10_a_s_12.15.06_inline.png)
Looking a bit further, it tries to do it (without success) on the new installed Summit, using the same SYSNAME_fe.x.y pattern (FE??? It is not compatible with EXOS, obviously).
![](https://d1uyvls174j03l.cloudfront.net/extremenetworks-us/attachment/RackMultipart20170810-93723-14kgwwm-Captura_de_Tela_2017-08-10_a_s_12.14.34_inline.png)
Anybody have any clue about it? Why it is doing it and how to disable this "feature"? (this is an unwanted behavior for our customer).
Best regards,
