EMC 8.1 adding vlan to EAPS domain script fails on EXOS switch version 12.4
‎01-26-2018 01:37 PM
Our company has in production Netsight 7.1.3.25 we have over 70 EAPS scripts in use and working as designed. Currently, I have recently installed EMC 8.1.0.52 on new VM, I have started mirroring the scripts that I have in Netsight 7 to EMC 8.1 and noticed when I tested the script my vlan does not get configured on older exos switches (12.4.) My questions is, is this a known issue or is there a workaround? Below is an example of the error and the Script I used.
EMC User: tcoronado
EMC User Domain:
CLI Login: r00t
X480-24x_COH_HEC_W 192.168.2.2 2018-01-25 at 09:40:38 CST
create vman plw_vman_test_tibo_fannin_996
* X480-24x_COH_HEC_W.2 #
config vman plw_vman_test_tibo_fannin_996 tag 996
* X480-24x_COH_HEC_W.3 #
disable igmp snooping vlan plw_vman_test_tibo_fannin_996
* X480-24x_COH_HEC_W.4 #
config eaps ch46_coh_fan_hec_ring add protected plw_vman_test_tibo_fannin_996
WARNING: Primary port [25] is not added to vlan "plw_vman_test_tibo_fannin_996", EAPS="ch46_coh_fan_hec_ring"
WARNING: Secondary port [26] is not added to vlan "plw_vman_test_tibo_fannin_996", EAPS="ch46_coh_fan_hec_ring"
* X480-24x_COH_HEC_W.5 #
Error: timeout waiting for data
#@MetaDataStart
#@DetailDescriptionStart
# Purpose : Example script to showcase how to declare a parameter and use it
#@DetailDescriptionEnd
#@VariableFieldLabel (description = "circuit Name",
# type = String,
# scope = global,
# required = yes
set var vlanname ""
#@VariableFieldLabel (description = "circuit Tag", type = String,
# scope = global,
# required = yes
set var vlannametag ""
# Parameter that can take values only from the given list of valid values
#@VariableFieldLabel (description = "Please choose correct service:", validValues = [vman, vlan])
set var foo2 vman
#@MetaDataEnd
# Enter all CLI commands from here
if {[string equal $foo2 "vman"]} {
create vman $vlanname
config vman $vlanname tag $vlannametag
disable igmp snooping vlan $vlanname
config ch46_coh_fan_hec_ring add protected $vlanname
config $vlanname add port $port tagged
regexp {.*could cause a loop.*} ${CLI.OUT} foundit
IF ([info exists foundit]) THEN
CLI y
ENDIF
else
create vlan $vlanname
config vlan $vlanname tag $vlannametag
regexp {.*Adding EAPS ring ports to a VLAN could cause a loop.*} ${CLI.OUT} foundit
CLI y
ENDIF
EMC User: tcoronado
EMC User Domain:
CLI Login: r00t
#@MetaDataStart
# type = String,
# scope = global,
# required = yes
set var vlanname ""
# scope = global,
# required = yes
set var foo2 vman
#@MetaDataEnd
CLI y
ENDIF
else
CLI y
ENDIF
5 REPLIES 5
‎01-26-2018 03:12 PM
Hi Tiburcio,
Please keep in mind that EXOS 12.4 and XMC aren't compatible. The current recommended version for the X480 is 16.2.4.5. Upgrading may resolve your issue.
Thanks
Brad
Thanks
Brad
