EMC Upgrade 8.0 - Expand disk problem
‎07-25-2017 06:55 AM
I just wanted to upgrade to from EMC 7.1 to EMC 8.0 and changed the VM settings with the colleagues from server according to the release-notes.
So far we had a 100 GiB disk and created a second disk with 380 GiB according to this article: http://documentation.extremenetworks.com/netsight/8.0/9034996-01_EMC_8.0_Add_Disk_Space.pdf
When I run the expandLVM.sh script with root-Access, the following output is logged:
13333 0 brw-rw---- 1 root disk 8, 0 Jul 25 10:39 /dev/sda
13337 0 brw-rw---- 1 root disk 8, 1 Jul 25 10:39 /dev/sda1
13338 0 brw-rw---- 1 root disk 8, 2 Jul 25 10:39 /dev/sda2
13339 0 brw-rw---- 1 root disk 8, 5 Jul 25 10:39 /dev/sda5
13336 0 brw-rw---- 1 root disk 8, 16 Jul 25 10:39 /dev/sdb
Can anyone give me a hint how to proceed?
Maybe the upgrade can be done with 30GiB free disk space as well?
I'm looking forward to your feedback
Best Regards
Chacko
When looking at the device-files, these devices are shown:
WARNING:
This script will attempt to locate a new virtual drive and add it to
the current LVM configuration. This script will format the new drive,
and should only be used in accordance with official instructions
to increase the size of the hard drive.
Would you like to proceed?: y
Starting partition resizing. Start size is 124GB
Logging to expandLVM.log
Scanning for new partition sdc
Scan could not detect new drive sdc, exiting.
Best Regards
Chacko
3 REPLIES 3
‎07-25-2017 08:39 AM
the expandLVM.sh script looks for an sdc drive to expand into, but your new drive appears to be sdb
You may edit script and change all sdb entries to sda, and all sdc enties to sdb
OR you may follow the expand steps manually:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-increase-disk-space-in-NetSight-VM
Glad I helped you
Thank you, that worked well 🙂
