EOS Out-Of-Band Management
Anonymous
Not applicable
‎04-19-2016 01:00 PM
In the process of configuring / designing an Out-Of-Band management network in EOS.
Will need to make this as secure as possible so things like SNMP, SSH, Syslog, HTTPS and Netflow for / via NetSight are all done out of band on the management network only. All the switches in use are either S or K series.
My first thoughts are that I would have to do this with Policy and ACL's, but it would be preferential to use a separate VRF.
So my questions are:
- What would the best why to ago about this in the most secure manner?
- Perhaps there is a better method in EOS?
- If I was to use a VRF for management (and my point in using it), is I could then just enable the management protocols on the management VRF and turn them off on the default VRF. (I don't believe its possible, but it would provide the simplest and most secure set-up, perhaps still in conjunction with policy and ACL's)
5 REPLIES 5
‎04-28-2016 06:30 PM
Here is a brief KB article, but maybe it is of use to you: https://gtacknowledge.extremenetworks.com/articles/Q_A/Non-Global-VRF-Loopback-IP-not-responding-to-...
What I take from that: Use the global VRF to perform management, and put your production traffic into a VRF that you create additionally.
‎04-20-2016 12:59 PM
I do not think that is sufficient.
There are two GTAC Knowledge articles regarding restricting management access:
- https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Configure-an-ACL-on-a-S-K-Series-to...
- https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-host-access-list-on-S-Series...
‎04-20-2016 12:13 PM
Question: if you set an ip address on an interface as management and then disable ip-forwarding on that interface does that restrict management access to that address?
Anonymous
Not applicable
‎04-20-2016 06:32 AM
Thanks for the reply.
Think my plan will be to use a VRF for management and use ACL's either side to stop and control IP traffic for containment, with the use of 'ip host-access' that you have helpfully provided.
Many thanks.
Many thanks.
