Exclude source or destination IP from PurView ?
Rainer_Adam
New Contributor III
Our Custerom uses a S8 as his Core Device, where is connected to all sublevel switches and directly to PurView Sensor and a VM Cluster of 2 maschines with more then 8 connections on the Core Switch.
We have enabled PurView redirect Policy on all Ports as it should be.
But, the have also solution based on 2 virtual maschines to check the status of Servers, Switches Printers and many other things that is able to handle SNMP. One of this virtual maschines defines when and what devices will be connected next (=Server) and the other one is working as a "Agent" that really handle all this polling jobs.
There are so many poll's from and between this 2 virtual servers that we run into a licence violation of PurView.
Is there a possibiltiy to leave the related physical Interfaces in Policy mirror state but will exclude traffic from and to the virtual servers/agents?
5 REPLIES 5
Mike_Thomas
Rainer, this should be possible.
But to be clear-you want to exclude two IP addresses from all reporting, or those IP only for certain protocols?
Please advice.
