10-19-2020 02:26 PM
We have 8 sets of EXOS stack switches consisting of 2 X460-G2’s each.
After upgrading to XMC 8.51 the switches will no longer upgrade automatically or manually
The error in the information section of the Inventory log is
Archive Save /World/X460-G2: (172.16.1.104) Version Stamp: Oct 16, 2020 12:00:00 AM - Error Archiving Configuration File. : Do you want to save configuration to primary.cfg and overwrite it? (y/N) Yes Saving configuration primary.cfg on master .. done! Synchronizing configuration to backup .... done! Slot-1 Rm 104 Switch.2 # extremeprompt ^ %% Invalid input detected at '^' marker. Slot-1 Rm 104 Switch.2 # extremeprompt ^ %% Invalid input detected at '^' marker. Slot-1 Rm 104 Switch.3 #
XMC version 8.5.0.169
Switch version 22.7.1.2 patch1-24
Thank you for the help
Solved! Go to Solution.
10-19-2020 02:32 PM
Hello,
this is a known issue in 8.5.0 and it is fixed in 8.5.1. Newer versions of EXOS (I believe 30.6 and newer) are also not affected.
You can also fix it by changing some files on the XMC Host.
Here is an article on this topic: https://gtacknowledge.extremenetworks.com/articles/Solution/000052674
Best regards
Stefan
10-21-2020 06:28 PM
Thank you for the response.
I have upgraded to version 8.5.2 and the archive issue has been resolved.
10-19-2020 02:32 PM
Hello,
Best regards
Stefan
