09-20-2018 04:16 AM
09-21-2018 02:56 AM
09-21-2018 02:56 AM
11-05-2019 08:08 PM
does this work with 8.3.2 and infoblox 8.4?
11-05-2019 08:15 PM
There is no change on XMC 8.3 = the same API calls works and new were added. No reason for different behavior with XMC 8.3. The same is valid for the upcoming XMC 8.4.
I did not check the new Infoblox versions if the API was changed.
