Extreme Management and Infoblox integration
Zdeněk_Pala
Do you know there is Extreme Management & Infoblox integration described and documented @ https://github.com/extremenetworks/Integrations/blob/master/Infoblox/README.md
Feel free to comment & update.
Be Extreme!
Regards Zdeněk Pala
7 REPLIES 7
mp2014
New Contributor II
Just thought about the other direction - infoblox --> NAC. How could this be achived? Triggering NMS API and fill one of the custom fields using mac address or ip addrress as key? Would be nice for getting the comment data from infoblox.
mp2014
New Contributor II
I got no test system, production only - but could test against single datasets.
does this work with 8.3.2 and infoblox 8.4?
There is no change on XMC 8.3 = the same API calls works and new were added. No reason for different behavior with XMC 8.3. The same is valid for the upcoming XMC 8.4.
I did not check the new Infoblox versions if the API was changed.
Regards Zdeněk Pala
