Extreme Management Config Templates shows detailed XML content
Anonymous
Not applicable
Not sure if anyone has tried the configuration template feature in Extreme Management 8.1 yet, but whenever I try to use it on EXOS devices (same on older versions of 8.1), I get whats shown in the screenshot below, taken from the current latest version 8.1.4.40:
31e3dca0a110450fa9b686739d84c871_RackMultipart20180930-102294-1rch77e-Template-Tool_inline.png
This works fine with EOS, i.e. it displays normal CLI as you would expect. But when using EXOS is displays detailed configuration in XML, I suspect that the reason is due to the .cfg file being used in the template for EXOS instead of the script file.
Is there perhaps an option I've missed, or is EXOS not supported yet?
Many thanks.
15 REPLIES 15
davidj_cogliane
Contributor
It would be great if we could use this feature with XOS.
If it is not in the pipeline, can we make this a feature request?
