File Not Available - Application Note - Extreme XOS IDM and NetSight Integration
Ben_Parker
New Contributor II
This file is no longer available from it's link even when we are logged into the support portal.
Here is the link to the orginal article and the file it points to inside.
https://community.extremenetworks.com/extreme/topics/application_note_extreme_xos_idm_and_netsight_i...
https://enterasys.box.com/s/m7xrjy0fml454t6ykk6t
Can this be re-posted somewhere we can have access to even if it is in the extranet?
Thank you,
Ben
3 REPLIES 3
Ben_Parker
New Contributor II
Thank you
dflouret
Here it is https://www.dropbox.com/s/z36fu5uquc5470j/appnotexos_idm_nsight%20integration%20.pdf?dl=0
Drew_C
Valued Contributor III
Hi Ben,
Thanks for pointing this out. I'll see if I can get a new link and have the post updated with it.
Maybe someone here has a copy of the IDM & NS guide you're looking for and can share it with you until this gets resolved.
In the meantime, you might find some useful information in the Extreme Networks Jumpstart guide, mentioned here:
https://community.extremenetworks.com/extreme/topics/xos-cli-cheat-sheet
Unfortunately that document points you to The Hub to pick up the one you're asking about... D'oh! I'll also have to see about getting that cleaned up in the guide.
-Drew
