08-12-2020 06:53 AM
I have a column in a flexview that I’d like to display a color button depending on the value. I was able to make that working in the console but in Oneview it does display the column, but no color button or the value, only a dash string. I was looking at the BOSS vlan flexview how it was done for the “vlan status”, I did the same but without success. Any hints?
Solved! Go to Solution.
08-18-2020 01:44 PM
It can be done = see example here
You can reverse engineer the example.
If your flexview works in Java Console then for OneView you need to manually edit the TPL file and change the value 2 (number) to 15 (string). The first number after EXPR;true represents the formating.
Example:
<dataField>SNMP::EXPR;true;15;
08-18-2020 01:44 PM
Example:
