Get "Top" output when alarm in EMC is triggered.
Byron_Morales
New Contributor II
I have an EXOS switch that intermittently triggers the “Device CPU Used %” for high CPU usage during  odd hours in the night.
Is there a way I can have EMC email the output of “top” or “show tech-support” automatically when this alarm is triggered?
1 REPLY 1
Anonymous
Not applicable
I’ve not tried this, but possibly using the action of ‘Task’ in the alarm configuration. Either create one that does the job required or use the canned ‘Gather Show Support’
Screenshots below take from version 8.3.0.11.
In addition there seems to be an available workflow here that might do the job:
https://github.com/extremenetworks/ExtremeScripting/blob/master/Netsight/oneview_workflows/README.md
‘Gather Show Support Based On Alarm’
Could possibly then be modified for Top
