Get values from OID add create own alarm in EMC
‎01-16-2018 12:59 PM
Hello,
is there a way to do an snmp get for arbitrary OIDs (for other vendors,too) and create an alarm if needed via a script (python, TCL, ...).
As I can see netsnmp for python is not installed. Can I install netsnmp and use it with the GUI scripting section on EMC (not the legacy tool)?
I will check some MIB values with a program logic and create an alarm or an syslog entry (with these syslog entry I can use the alarm manager in a second step).
Best regards
Stephan
Best regards
Stephan
Regards
Stephan
6 REPLIES 6
‎01-22-2018 08:24 PM
do you want to share the final script with us? would be great
Thanks for coming back to share the answer 🙂
