How do I add historical statistic avability in NetSight?
Angel_Pavon1
New Contributor III
Hello, how can I add the next avability historical statistic for my divices in NetSight?. I just can see the avability in real time.
f1b4aa2ce8da468db789b84a12bc6219_RackMultipart20170914-59403-1jj1gek-NetSight_inline.png
Regards
2 REPLIES 2
Angel_Pavon1
New Contributor III
Hello Joshua thank you !!
Regards
Joshua_Puusep
New Contributor III
Howdy,
If you go to Network>Reports>Device Availability Summary, you should be able to modify the time range and see historical data.
If not, go to "Network>Devices". Right click on the device in question, select "Device>Collect Device statistics" and make sure that "Historical" is selected.
Allow 30 minutes or so for collection data polling.
