I'm using Extreme Management Center version 8.1.4.40 with base licence. I'm looking for a way to get a listing of unused port for the last 1 year.
I configured a daily task to collect "capacity planning" data but I'm stuck in the generation of a report like Ridgeline software did previously. And the "Capacity Planning" menu in Extreme Management Center's Dashborad just show a red disk indicating 100% not collected...
For the moment, I try to check on demand, device per device, but I loose a lot of time and if the device has rebooted less than 1 year ago then I can't get a useful report.
All my switches are running ExtremeXOS (from version 12.x to the last 22.x).
Does anybody know a way to perfom this ?
Regards,
Romain M.
