How to use XMC to configure Unify phone or Cisco Phone with LLDP-MED
‎12-14-2021 04:25 PM
Hi everyone,
I have an XMC system and X440 switches. I need to authenticate unify or Cisco phones using the LLDP-MED protocol.
Is this possible?
I have created a policy in the NAC that analyzes the mac-address but I want to exploit the potential of the LLDP-MED protocol and XMC to configure the phone with the vlan correct (egress tagged for voip and pvid untagged for data for example ). Thanks to all
Giuseppe
6 REPLIES 6
‎12-15-2021 03:25 AM
Hi Zdeněk Pala, I have XMC and NAC. I have created a policy to check OUI and it works but only whit the port untagged.
I am not able to add lldp parameter to put the phone on the "voice vlan " as tagged.
Thanks
Giuseppe
Thanks
Giuseppe
‎12-15-2021 02:55 AM
Hi Giuseppe.
there are several options:
Z.
- use NAC (ExtremeControl). Based on MAC address (OUI or list) you can assign the policy through Radius Access Accept
- use UPM scripting. Based on the event generated by the switch the switch can assign policy to the port. check the Universal Port section of the documentation = https://documentation.extremenetworks.com/exos_31.5/GUID-7C3FD5E9-0088-4BFA-82C9-954A70BB9A52.shtml
Z.
Regards
Zdeněk Pala
