Is there a way to manage port poe on and Exos switch through NetSight
davidj_cogliane
Contributor
We have a customer who wants to reset inline-power on an Exos port using NetSight. I was trying to create a column in a FlexView and thought I found the right mib.
extremePethPortResetPower OBJECT-TYPE SYNTAX INTEGER { set(1), clear(2) }
MAX-ACCESS read-write
STATUS current
DESCRIPTION
"Resets the power on the port. Reading always returns clear(2)"
::= { extremePethPsePortEntry 5 }
I have tried this on several code versions including 16.1 but always get the red X.
NetSight is 6.3.0.162 and 6.3.0.168 same results on both
Any help would be greatly appreciated.
15 REPLIES 15
Mike_Thomas
Did you try setting it using Mibtools first, to take the complexity of Flexviews out of it?
