Is there a way to manage port poe on and Exos switch through NetSight
davidj_cogliane
Contributor
We have a customer who wants to reset inline-power on an Exos port using NetSight. I was trying to create a column in a FlexView and thought I found the right mib.
extremePethPortResetPower OBJECT-TYPE SYNTAX INTEGER { set(1), clear(2) }
MAX-ACCESS read-write
STATUS current
DESCRIPTION
"Resets the power on the port. Reading always returns clear(2)"
::= { extremePethPsePortEntry 5 }
I have tried this on several code versions including 16.1 but always get the red X.
NetSight is 6.3.0.162 and 6.3.0.168 same results on both
Any help would be greatly appreciated.
15 REPLIES 15
Drew_C
Valued Contributor III
That xkit site may be decommissioned soon. All of the content has been migrated to gitHub.
https://github.com/extremenetworks
Thank you
This is very interesting information and I will investigate deployment of this at our office for testing.
Unfortunately this does not help with the issue I am currently working on. Our customer has some problem cameras that require a reboot from time to time. That is why I am trying to get this flexview to work.
But again thanks for the information I look forward to investigating it further.
davidj_cogliane
Contributor
Ok so I found that and am able to get it to work through the mib tool useing
extremePethPortResetPower=1.3.6.1.4.1.1916.1.27.2.1.1.5
set powers it down and clear powers it up.
In the flexview I do not even get the same output. In the mib tool it shows clear in the flexview it shows N/A
Here is a link to the tpl file
https://www.dropbox.com/s/wo9w3klwdfhgims/POE%20Status%203.tpl?dl=0
It seems like there has to be a check box or something that is making the FlexView send the information differently than the mib tool is.
Thanks for your help
Mike_Thomas
You should be able to set to the 1 or 2 value above, if you get a set failed, make sure you have write credentials set correctly.
You could try changing sysLocation or sysLocation for instance, a very common writeable MIB. That would be a baseline
davidj_cogliane
Contributor
I get an output from the mib query using the mib tool but did not know disabling the port from there would be possible.
