NAC EVENTS to Thrid Party SIEM
Jimmy_Payne1
Does anyone have any hands on experience sending NAC events to a Mcafee SIEM receiver? It appears that everything is set correctly but I am not seeing events in my SIEM. Any help would be greatly appreciated.
8 REPLIES 8
Kurt_Semba
Hey Jimmy, So it seems as either NetSight is not sending the data or something like a firewall is blocking the data before it hits the SIEM. To validate whether the syslog messages are leaving the NetSight appliance, use tcpdump or wireshark (usually udp port 514).
Jimmy_Payne1
Hi Kurt Yes I did set those options in NAC and I did a tcpdump on my receiver to see if there were events coming in and there were none. So I am still stumped on that whole deal. Sorry for the late reply. We had some crazy stuff going on around here this week.
Tamera_Rousseau
Hi Jimmy, Thanks for asking this question in our community as well as McAfee. Hopefully you can give Kurt some additional data to point you in the right direction.
Kurt_Semba
Did you use NAC notification configuration to send syslog events to your SIEM? Is there a way (tcpdump) to check whether those events are received on the SIEM appliance? If they are, it's probably a parsing issue or a matter of allowing events from NAC to be received. You can change the syslog messages' format/content in NAC's notification configuration ("overwrite content") or you might be able to change the parsing logic on the McAfee side.
