netsight 6 java error unsigned entry found in jar
‎04-17-2014 01:09 PM
since Netsight upgrade from 5 to 6 (6.0.0.78) the Console cannot start, if Java Cache is disabled. After downloading and loading the console application (console.jnlp) an error occours "Unable to start application" with the Detail "com.sun.deploy.net.JARSigningException: Found unsigned entry in resource: http://netsight:8080/Clients/plugins/AclMgr/forms-1.0.5.jar"
Set Java Cache Config to default (Cache enabled) works around the problem.
solution found here: http://blog.atlashost.eu/post/found-unsigned-entry-in-resource-java-web-start.html
5 REPLIES 5
‎04-17-2014 03:48 PM
Hi Stefan. I will send along a note to our Netsight experts. Thank you!
