NetSight Alarms per SMS
Norman_Sobe
hello
times a question can be seen from the NetSight® Console alarm per SMS
send?
9 REPLIES 9
Norman_Sobe
Thanks
jeronimo
Contributor III
Go read the Netsight help about Alarms/Events. As I said you can trigger scripts which can do anything including an SMS gateway or whatever. If you don't feel comfortable, contact someone to do it for you.
Norman_Sobe
Which guide is what sent via SMS
jeronimo
Contributor III
You can download the NMS manual and read about events. Probably the help will help too 🙂
